Home
Download
Hall Of Fame
Docs
FAQ
Resources & Support
Forums
Search
Login
POV-Ray
Documentation
: 3.5 Menus
POV-Ray 3.6 Documentation Online View
3.4.7 The Render Window
3.5.1 File Menu
3.5
Menus
Section Contents
3.5.1 File Menu
3.5.1.1 New File
3.5.1.2 Open File
3.5.1.3 Close
3.5.1.4 Close All
3.5.1.5 Print
3.5.1.6 Exit
3.5.1.7 MRU List
3.5.1.8 Older Files
3.5.2 Edit Menu
3.5.2.1 Copy Pane
3.5.2.2 Clear Messages
3.5.2.3 Undo
3.5.2.4 Redo
3.5.2.5 Cut
3.5.2.6 Copy
3.5.2.7 Paste
3.5.2.8 Delete
3.5.2.9 Select All
3.5.2.10 Selection
3.5.2.10.1 Indent
3.5.2.10.2 Indent To Previous
3.5.2.10.3 Undent
3.5.2.10.4 Uppercase
3.5.2.10.5 Lowercase
3.5.2.10.6 Convert Spaces To Tabs
3.5.2.10.7 Convert Tabs To Spaces
3.5.3 Search Menu
3.5.3.1 Find
3.5.3.1.1 Match Whole Word Only
3.5.3.1.2 Match Case
3.5.3.1.3 Wildcard Search
3.5.3.2 Replace
3.5.3.3 Find Next
3.5.3.4 Match Brace
3.5.4 Text Menu
3.5.4.1 Show White Space
3.5.4.2 Set Repeat Count
3.5.4.3 Tab Size
3.5.4.4 Indent
3.5.4.4.1 Auto-Indent Style
3.5.4.4.2 None
3.5.4.4.3 Language Scope
3.5.4.4.4 Copy From Previous Line
3.5.4.5 Bookmarks
3.5.4.5.1 Clear All
3.5.4.5.2 First
3.5.4.5.3 Last
3.5.4.5.4 Next
3.5.4.5.5 Previous
3.5.4.5.6 Toggle
3.5.5 Editor Menu
3.5.5.1 Auto-Load Error File
3.5.5.2 Auto-Show Parse Messages
3.5.5.3 Auto-Save Delay
3.5.5.4 Create Backups
3.5.5.5 Allow Undo After Manual Save
3.5.5.6 Click Beyond EOL
3.5.5.7 Constrain Caret To Text
3.5.5.8 Overlay Keyword Expansion On Tab Key
3.5.5.9 Show Message Window
3.5.5.10 Editor Preferences Dialog
3.5.5.11 Record Macro/Play Macro
3.5.5.12 Auto-Reload
3.5.5.13 Scroll Bars
3.5.5.14 Color Scheme
3.5.5.15 Editor Preferences
3.5.5.15.1 Color/Font
3.5.5.15.2 Language/Tabs
3.5.5.15.3 Keyboard
3.5.5.15.4 Misc
3.5.6 Insert Menu
3.5.6.1 How the Insert Menu is Built
3.5.6.2 Physical Layout
3.5.6.3 Sorting the Insert Menu
3.5.6.4 Adding a Separator
3.5.6.5 Using the Insert Menu
3.5.7 Render Menu
3.5.7.1 Edit Settings/Render
3.5.7.2 Select File and Render
3.5.7.3 Start Rendering (Go!)/Stop Rendering
3.5.7.4 Run Demo
3.5.7.5 Run Benchmark
3.5.7.6 File Queue
3.5.7.7 Clear Queue
3.5.7.8 Animation Pane
3.5.7.8.1 Minimize Shellouts
3.5.7.8.2 No Shellout Wait
3.5.7.9 Render Priority
3.5.7.10 Duty Cycle
3.5.7.11 Sound Settings
3.5.7.12 On Completion
3.5.7.12.1 Do Nothing
3.5.7.12.2 Display Message
3.5.7.12.3 Exit POV-Ray for Windows
3.5.7.13 Rerun
3.5.7.13.1 Rerun Dialog
3.5.7.13.2 Rerun
3.5.7.13.3 Continue
3.5.7.13.4 File List
3.5.8 Options Menu
3.5.8.1 Keep Single Instance
3.5.8.2 Use Render Animation
3.5.8.3 Show Toolbar
3.5.8.4 Place in System Tray
3.5.8.5 Script I/O Restrictions
3.5.8.6 Drag'N'Drop Destination
3.5.8.7 Online Operations
3.5.8.8 Check For New Versions
3.5.8.9 Include System Information
3.5.8.10 Other Settings
3.5.8.10.1 Use Editor
3.5.8.10.2 Show Tips of the Day
3.5.8.10.3 Show Tooltips
3.5.8.10.4 Preserve Messages
3.5.8.10.5 Save Settings on Exit
3.5.8.10.6 Hide New User Help
3.5.8.10.7 Show Next Tip
3.5.8.10.8 Re-Render Insert Menu Bitmaps
3.5.8.10.9 Message Window
3.5.8.10.10 Select Plain Background
3.5.8.10.11 Text Font
3.5.8.10.12 Text Color
3.5.8.10.13 Background Color
3.5.8.10.14 Tiling Options
3.5.8.10.15 Render Window
3.5.8.10.16 Force 8 Bit Display
3.5.8.10.17 Preserve Contents During Animation
3.5.8.10.18 Re-display
3.5.8.10.19 Autoclose
3.5.8.10.20 Close
3.5.8.10.21 Keep Above Main
3.5.8.10.22 Get Focus on Creation
3.5.8.10.23 Hide When Main Minimized
3.5.8.10.24 Editor Window
3.5.9 Tools Menu
3.5.9.1 Syntax Coloring
3.5.9.2 Reload Tool Menu
3.5.9.3 Edit PVTOOLS.INI
3.5.9.4 Example PVTOOLS.INI
3.5.9.5 GUI Extensions Menu
3.5.10 Context Menus
3.5.10.1 The Message Window Context Menu
3.5.10.2 Minimize to System Tray
3.5.10.3 Show Tip
3.5.10.4 The Render Window Context Menu
3.5.10.5 The Editor Window Context Menu
3.5.10.6 Show or Hide Messages
3.5.10.7 Context Help
3.5.10.8 Open <Filename>
3.5.10.9 Copy "..." to Command-Line
3.5.1 File Menu
