Searches the file for the first occurance of a specific string of text and highlights/selects it.
3.5.3.1.1 Match Whole Word Only
If this option is checked, partial matches will not occur (for example, the search string 'Persist' will not find
the word 'Persistence', whereas normally it would).
If this option is checked, then the case of the search string and the searched-for text will be the same.
The search string allows the following wildcard characters if the "Wildcard Search" option is checked -
Matches any single character
Matches one or more of the previous character or item (which may be a wildcard or group), up to a maximum of the
end of the line. For example, ?+ will match from the next character to the end of the line, and [0-9.]+
will match any number, with or without a decimal point.
This operator works like '+' above, but matches zero or more rather than one or more. Put another way, it makes
the previous character or item optional.
Characters enclosed in square brackets will be treated as an inclusive set. Character ranges may be specified
with a '-' (e.g. [a-c] would match the characters 'a', 'b', or 'c').
Subexpressions may be ORed together with the | pipe symbol.
A wildcard expression may be enclosed within parentheses and will be treated as a unit.
Sequences such as \t, etc. will be substituted for an equivalent single character. To represent a literal
backslash, use two (e.g. \\ ).
Be aware that the wildcard search facility does have some bugs in it and may not always match
correctly (e.g. [0-9A-Za-z] will match all alphanumerics, but [A-Za-z0-9] does not match
numbers, even though it should).
