3.5.6.2 Physical Layout
Each sub-menu in the Insert Menu is a directory (also called a 'folder' these days). To create a new sub-menu, just
create a new directory. The submenu will have the same name as the directory.
The actual items that you can insert in your scene files are simply text files. POVWIN recognizes them by the
extension .TXT. Any .TXT file in the Insert Menu directory tree will appear in the Insert Menu. The name shown in the
Insert Menu will be the filename of the .TXT file, minus the .TXT extension. If you select this file from the Insert
Menu, the contents of the corresponding text file will be inserted into your scene file at the current cursor
location.
