2.5.12.4 Noise Generators
There are three noise generators implemented. Changing the noise_generator will change the appearance
of noise based patterns, like bozo and granite.
noise_generator 1 the noise that was used in POV_Ray 3.1
noise_generator 2 'range corrected' version of the old noise, it does not show the plateaus seen
with noise_generator 1
noise_generator 3 generates Perlin noise
The default is noise_generator 2
Note: The noise_generator can also be set in global_settings
