POV-Ray allows you to apply various wave forms to the pattern function before applying it to a blend map. Blend
maps are color_map , pigment_map , normal_map , slope_map , density_map ,
and texture_map .
Most of the patterns which use a blend map, use the entries in the map in order from 0.0 to 1.0. The effect can
most easily be seen when these patterns are used as normal patterns with no maps. Patterns such as gradient
or onion generate a groove or slot that looks like a ramp that drops off sharply. This is called a ramp_wave
wave type and it is the default wave type for most patterns. However the wood and marble
patterns use the map from 0.0 to 1.0 and then reverses it and runs it from 1.0 to 0.0. The result is a wave form which
slopes upwards to a peak, then slopes down again in a triangle_wave . In earlier versions of POV-Ray
there was no way to change the wave types. You could simulate a triangle wave on a ramp wave pattern by duplicating
the map entries in reverse, however there was no way to use a ramp wave on wood or marble.
Now any pattern that takes a map can have the default wave type overridden. For example:
pigment { wood color_map { MyMap } ramp_wave }
Also available are sine_wave , scallop_wave , cubic_wave and poly_wave
types. These types are of most use in normal patterns as a type of built-in slope map. The sine_wave
takes the zig-zag of a ramp wave and turns it into a gentle rolling wave with smooth transitions. The scallop_wave
uses the absolute value of the sine wave which looks like corduroy when scaled small or like a stack of cylinders when
scaled larger. The cubic_wave is a gentle cubic curve from 0.0 to 1.0 with zero slope at the start and
end. The poly_wave is an exponential function. It is followed by an optional float value which specifies
exponent. For example poly_wave 2 starts low and climbs rapidly at the end while poly_wave 0.5
climbs rapidly at first and levels off at the end. If no float value is specified, the default is 1.0 which produces a
linear function identical to ramp_wave .
Although any of these wave types can be used for pigments, normals, textures, or density the effect of many of the
wave types are not as noticeable on pigments, textures, or density as they are for normals.
Wave type modifiers have no effect on block patterns checker , brick , object
and hexagon nor do they effect image_map , bump_map or material_map .
They also have no effect in normal statements when used with bumps , dents , quilted ,
ripples , waves , or wrinkles because these normal patterns cannot use normal_map
or slope_map .
