The granite pattern uses a simple 1/f fractal noise function to give a good granite pattern. This
pattern is used with creative color maps in stones.inc to create some gorgeous layered stone textures.
As a normal pattern it creates an extremely bumpy surface that looks like a gravel driveway or rough stone.
Note: The appearance of the granite pattern depends on the noise_generator used. The
default type is 2. This may be changed using the noise_generator keyword (See section "Pattern
Modifiers / Noise_generator").
More about "Noise_generator"
