3.5.7.3 Start Rendering (Go!)/Stop Rendering
This is a toggle. If you are not currently rendering, the command Start Rendering instructs POV-Ray for Windows to
start rendering the currently loaded POV file with the current settings. While POV-Ray for Windows is rendering, the
command reads Stop Rendering and will interrupt the current rendering job. You can continue an interrupted rendering
job by selecting 'Continue <filename>' from the Rerun Menu.
