3.5.7.2 Select File and Render
This is the way to select a file from disk for immediate rendering. If the file is a POV file, it is rendered with
the current options. If it is an INI file with no POV input file specified, the options will apply to the currently
loaded POV file, only to be overridden by command-line settings. If the INI file specifies a POV input file, that POV
scene is rendered with the options set in the INI file. See also Understanding File Types.
More about "Understanding File Types"
