2.3.3 Global Settings
The global_settings statement is a catch-all statement that gathers together a number of global
parameters. The statement may appear anywhere in a scene as long as it is not inside any other statement. You may have
multiple global_settings statements in a scene. Whatever values were specified in the last global_settings
statement override any previous settings.
Note: some items which were language directives in earlier versions of POV-Ray have
been moved inside the global_settings statement so that it is more obvious to the user that their effect
is global. The old syntax is permitted but generates a warning.
The new syntax is:
GLOBAL_SETTINGS:
global_settings { [GLOBAL_SETTINGS_ITEMS...] }
GLOBAL_SETTINGS_ITEM:
adc_bailout Value | ambient_light COLOR | assumed_gamma Value |
hf_gray_16 [Bool] | irid_wavelength COLOR |
charset GLOBAL_CHARSET | max_intersections Number |
max_trace_level Number | number_of_waves Number |
noise_generator Number | radiosity { RADIOSITY_ITEMS... } |
photon { PHOTON_ITEMS... }
GLOBAL_CHARSET:
ascii | utf8 | sys
Global setting default values:
charset : ascii
adc_bailout : 1/255
ambient_light : <1,1,1>
assumed_gamma : No gamma correction
hf_gray_16 : off
irid_wavelength : <0.25,0.18,0.14>
max_trace_level : 5
max_intersections : 64
number_of_waves : 10
noise_generator : 2
Radiosity:
adc_bailout : 0.01
always_sample : on
brightness : 1.0
count : 35 (max = 1600)
error_bound : 1.8
gray_threshold : 0.0
low_error_factor : 0.5
max_sample : non-positive value
minimum_reuse : 0.015
nearest_count : 5 (max = 20)
normal : off
pretrace_start : 0.08
pretrace_end : 0.04
recursion_limit : 3
Each item is optional and may appear in any order. If an item is specified more than once, the last setting
overrides previous values. Details on each item are given in the following sections.
