![](/i/fill.gif) |
The camera definition describes the position, projection type and properties of the camera viewing the scene. Its
syntax is:
CAMERA:
camera{ [CAMERA_ITEMS...] }
CAMERA_ITEM:
CAMERA_TYPE | CAMERA_VECTOR | CAMERA_MODIFIER |
CAMERA_IDENTIFIER
CAMERA_TYPE:
perspective | orthographic | fisheye | ultra_wide_angle |
omnimax | panoramic | cylinder CylinderType | spherical
CAMERA_VECTOR:
location <Location> | right <Right> | up <Up> |
direction <Direction> | sky <Sky>
CAMERA_MODIFIER:
angle HORIZONTAL [VERTICAL] | look_at <Look_At> |
blur_samples Num_of_Samples | aperture Size |
focal_point <Point> | confidence Blur_Confidence |
variance Blur_Variance | NORMAL | TRANSFORMATION
Camera default values:
DEFAULT CAMERA:
perspective
location <0,0,0>
direction <0,0,1>
right 1.33*x
up y
sky <0,1,0>
CAMERA TYPE: perspective
angle : ~67.380 ( direction_length=0.5*
right_length/tan(angle/2) )
confidence : 0.9 (90%)
direction : <0,0,1>
focal_point: <0,0,0>
look_at : z
right : 1.33*x
sky : <0,1,0>
up : y
variance : 1/128
Depending on the projection type zero or more of the parameters are required:
If no camera is specified the default camera is used.
If no projection type is given the perspective camera will be used (pinhole camera).
The CAMERA_TYPE has to be the first item in the camera statement.
Other CAMERA_ITEMs may legally appear in any order.
For other than the perspective camera, the minimum that has to be specified is the CAMERA_TYPE, the cylindrical
camera also requires the CAMERA_TYPE to be followed by a float.
The Orthographic camera has two 'modes'. For the pure orthographic projection up or right have to be specified.
For an orthographic camera, with the same area of view as a perspective camera at the plane which goes through the
look_at point, the angle keyword has to be use. A value for the angle is optional.
All other CAMERA_ITEMs are taken from the default camera, unless they are specified differently.
![](/i/fill.gif) |
