1.4.7.3 No beep when finished?
"How can I get rid of the beep after POV-Ray has calculated the image"
Usually using the -P command-line option should help (POV-Ray will not pause after it has calculated
the image). If you are using the windows version of POV-Ray, you can try Render -> On Completion -> Remove [v]
in front of "Beep".
