POV-Ray : Documentation : 2.3.3 Global Settings
  POV-Ray 3.6 Documentation Online View
2.3.2.5 Rainbow   2.3.3.1 ADC_Bailout
The global_settings statement is a catch-all statement that gathers together a number of global parameters. The statement may appear anywhere in a scene as long as it is not inside any other statement. You may have multiple global_settings statements in a scene. Whatever values were specified in the last global_settings statement override any previous settings.
Note: some items which were language directives in earlier versions of POV-Ray have been moved inside the global_settings statement so that it is more obvious to the user that their effect is global. The old syntax is permitted but generates a warning.
The new syntax is:
GLOBAL_SETTINGS:
    global_settings { [GLOBAL_SETTINGS_ITEMS...] }
GLOBAL_SETTINGS_ITEM:
    adc_bailout Value | ambient_light COLOR | assumed_gamma Value |
    hf_gray_16 [Bool] | irid_wavelength COLOR |
    charset GLOBAL_CHARSET | max_intersections Number |
    max_trace_level Number | number_of_waves Number |
    noise_generator Number | radiosity { RADIOSITY_ITEMS... } |
    photon { PHOTON_ITEMS... }
GLOBAL_CHARSET:
    ascii | utf8 | sys
Global setting default values:
charset            : ascii
adc_bailout        : 1/255
ambient_light      : <1,1,1>
assumed_gamma      : No gamma correction
hf_gray_16         : off
irid_wavelength    : <0.25,0.18,0.14>
max_trace_level    : 5
max_intersections  : 64
number_of_waves    : 10
noise_generator    : 2
Radiosity:
  adc_bailout      : 0.01
  always_sample    : on
  brightness       : 1.0
  count            : 35  (max = 1600)
  error_bound      : 1.8
  gray_threshold   : 0.0
  low_error_factor : 0.5
  max_sample       : non-positive value
  minimum_reuse    : 0.015
  nearest_count    : 5   (max = 20)
  normal           : off
  pretrace_start   : 0.08
  pretrace_end     : 0.04
  recursion_limit  : 3
Each item is optional and may appear in any order. If an item is specified more than once, the last setting overrides previous values. Details on each item are given in the following sections.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
