2.5.12 Pattern Modifiers
Pattern modifiers are statements or parameters which modify how a pattern is evaluated or tells what to do with the
pattern. The complete syntax is:
PATTERN_MODIFIER:
BLEND_MAP_MODIFIER | AGATE_MODIFIER | DENSITY_FILE_MODIFIER |
QUILTED_MODIFIER | BRICK_MODIFIER | SLOPE_MODIFIER |
noise_generator Number| turbulence <Amount> |
octaves Count | omega Amount | lambda Amount |
warp { [WARP_ITEMS...] } | TRANSFORMATION
BLEND_MAP_MODIFIER:
frequency Amount | phase Amount | ramp_wave | triangle_wave |
sine_wave | scallop_wave | cubic_wave | poly_wave [Exponent]
AGATE_MODIFIER:
agate_turb Value
BRICK_MODIFIER:
brick_size Size | mortar Size
DENSITY_FILE_MODIFIER:
interpolate Type
SLOPE_MODIFIERS:
<Altitude>
<Lo_slope,Hi_slope>
<Lo_alt, Hi_alt>
QUILTED_MODIFIER:
control0 Value | control1 Value
PIGMENT_MODIFIER:
PATTERN_MODIFIER | COLOR_LIST | PIGMENT_LIST |
color_map { COLOR_MAP_BODY } | colour_map { COLOR_MAP_BODY } |
pigment_map{ PIGMENT_MAP_BODY } | quick_color COLOR |
quick_colour COLOR
COLOR NORMAL_MODIFIER:
PATTERN_MODIFIER | NORMAL_LIST |
normal_map { NORMAL_MAP_BODY } | slope_map{ SLOPE_MAP_BODY } |
bump_size Amount
TEXTURE_PATTERN_MODIFIER:
PATTERN_MODIFIER | TEXTURE_LIST |
texture_map{ TEXTURE_MAP_BODY }
DENSITY_MODIFIER:
PATTERN_MODIFIER | DENSITY_LIST | COLOR_LIST |
density_map { DENSITY_MAP_BODY }
Default values for pattern modifiers:
dist_exp : 0
falloff : 2.0
frequency : 1.0
lambda : 2.0
major_radius : 1
map_type : 0
noise_generator : 2
octaves : 6
omega : 0.5
orientation : <0,0,1>
phase : 0.0
poly_wave : 1.0
strength : 1.0
turbulence : <0,0,0>
The modifiers PIGMENT_LIST, quick_color, and pigment_map apply only to
pigments. See section "Pigment" for details on these pigment-specific pattern modifiers.
The modifiers COLOR_LIST and color_map apply only to pigments and densities. See sections
"Pigment" and "Density" for
The modifiers NORMAL_LIST, bump_size, slope_map and normal_map
apply only to normals. See section "Normal" for details on these normal-specific pattern
modifiers.
The TEXTURE_LIST and texture_map modifiers can only be used with patterned textures. See
section "Texture Maps" for details.
The DENSITY_LIST and density_map modifiers only work with media{density{..}}
statements. See "Density" for details.
The agate_turb modifier can only be used with the agate pattern. See "Agate"
for details.
The brick_size and mortar modifiers can only be used with the brick
pattern. See "Brick" for details.
The control0 and control1 modifiers can only be used with the quilted
pattern. See "Quilted" for details.
The interpolate modifier can only be used with the density_file pattern. See "Density_File"
for details.
The general purpose pattern modifiers in the following sections can be used with pigment, normal,
texture, or density patterns.
More about "Pigment"
More about "Normal"
