1.2.7.4 Transform Identifiers
At times it is useful to combine together several transformations and apply them in multiple places. A transform
identifier may be used for this purpose. Transform identifiers are declared as follows:
TRANSFORM_DECLARATION:
#declare IDENTIFIER = transform{ TRANSFORMATION... } |
#local IDENTIFIER = transform{ TRANSFORMATION... }
Where IDENTIFIER is the name of the identifier up to 40 characters long and TRANSFORMATION is any
valid transformation modifier. See "#declare vs. #local" for
information on identifier scope. Here is an example...
#declare MyTrans =
transform {
rotate THISWAY
scale SOMUCH
rotate -THISWAY
scale BIGGER
translate OVERTHERE
rotate WAYAROUND
A transform identifier is invoked by the transform keyword with or without brackets as shown here:
object {
MyObject // Get a copy of MyObject
transform MyTrans // Apply the transformation
translate -x*5 // Then move it 5 units left
object {
MyObject // Get another copy of MyObject
transform { MyTrans } // Apply the same transformation
translate x*5 // Then move this one 5 units right
On extremely complex CSG objects with lots of components it may speed up parsing if you apply a declared
transformation rather than the individual translate, rotate, scale, or
matrix modifiers. The transform is attached just once to each component. Applying each individual translate,
rotate, scale, or matrix modifiers takes longer. This only affects parsing -
rendering works the same either way.
