Float Expressions
FLOAT:
NUMERIC_TERM [SIGN NUMERIC_TERM]...
SIGN:
NUMERIC_TERM:
NUMERIC_FACTOR [MULT NUMERIC_FACTOR]...
MULT:
NUMERIC_EXPRESSION:
FLOAT_LITERAL | FLOAT_IDENTIFIER | SIGN NUMERIC_EXPRESSION | FLOAT_FUNCTION | FLOAT_BUILT_IN_IDENT | ( FULL_EXPRESSION )
| ! NUMERIC_EXPRESSION | VECTOR.DOT_ITEM | FLOAT_FUNCTION_INVOCATION
FLOAT_LITERAL:
[DIGIT...][.]DIGIT...[EXP[SIGN]DIGIT...]
DIGIT:
0 | 1 | 2 | 3 | 4 | 5
| 6 | 7 | 8 | 9
EXP:
e | E
FLOAT_FUNCTION:
abs (FLOAT) | acos (FLOAT) | acosh (FLOAT)
| asc (STRING) | asin (FLOAT) | asinh (FLOAT)
| atan (FLOAT) | atanh (FLOAT) | atan2 (FLOAT,FLOAT)
| ceil (FLOAT) | cos (FLOAT) | cosh (FLOAT)
| defined (IDENTIFIER) | degrees (FLOAT)
| dimensions (ARRAY_IDENTIFIER) | dimension_size (ARRAY_IDENTIFIER,INT)
| div (FLOAT,FLOAT) | exp (FLOAT) | file_exists (STRING)
| floor (FLOAT) | int (FLOAT) | inside (SOLID_OBJECT_IDENT,
VECTOR) | ln (FLOAT) | log (FLOAT)
| max (FLOAT,FLOAT[,FLOAT]...) | min (FLOAT,FLOAT[,FLOAT]...)
| mod (FLOAT,FLOAT) | pow (FLOAT,FLOAT)
| radians (FLOAT) | rand (FLOAT) | seed (FLOAT)
| select (FLOAT,FLOAT,FLOAT,[FLOAT]) | sin (FLOAT)
| sinh (FLOAT) | sqrt (FLOAT) | strcmp (STRING,STRING)
| strlen (STRING) | tan (FLOAT) | tanh (FLOAT)
| val (STRING) | vdot (VECTOR,VECTOR) | vlength (VECTOR)
FLOAT_BUILT_IN_IDENT:
BOOLEAN_KEYWORD | clock | clock_delta | clock_on | final_clock
| final_frame | frame_number | image_height | image_width
| initial_clock | initial_frame | pi | version
BOOLEAN_KEYWORD:
true | yes | on | false | no
| off
FULL_EXPRESSION:
LOGICAL_EXPRESSION [? FULL_EXPRESSION : FULL_EXPRESSION]
LOGICAL_EXPRESSION:
REL_TERM [LOGICAL_OPERATOR REL_TERM]...
LOGICAL_OPERATOR:
REL_TERM:
FLOAT [REL_OPERATOR FLOAT]...
REL_OPERATOR:
DOT_ITEM:
x | y | z | t | u | v
| red | green | blue | filter | transmit
| gray
INT:
FLOAT
Any fractional part is discarded.
BOOL:
BOOLEAN_KEYWORD | LOGICAL_EXPRESSION
Quick Reference Contents
