2.7.17.7 Texture and pattern macros
Irregular_Bricks_Ptrn (Mortar Thickness, X-scaling, Variation, Roundness) . This function pattern
creates a pattern of bricks of varying lengths on the x-y plane. This can be useful in building walls that do not look
like they were built by a computer. Note that mortar thickness between bricks can vary somewhat, too. Parameters:
Mortar Thickness = Thickness of the mortar (0-1).
X-scaling = The scaling of the bricks (but not the mortar) in the x direction.
Variation = The amount by which brick lengths will vary (0=none, 1=100%).
Roundness = The roundness of the bricks (0.01=almost rectangular, 1=very round).
Tiles_Ptrn() . This macro creates a repeating box pattern on the x-y plane. It can be useful for
creating grids. The cells shade continuously from the center to the edges. Parameters: None.
Hex_Tiles_Ptrn() . This macro creates a pattern that is a sort of cross between the hexagon pattern and
a repeating box pattern. The hexagonal cells shade continuously from the center to the edges. Parameters: None.
Star_Ptrn (Radius, Points, Skip) . This macro creates a pattern that resembles a star. The pattern is
in the x-y plane, centered around the origin. Parameters:
Radius = The radius of a circle drawn through the points of the star.
Points = The number of points on the star.
Skip = The number of points to skip when drawing lines between points to form the star. A normal
5-pointed star skips 2 points. A Star of David also skips 2 points. Skip must be less than Points/2 and greater than
0. Integers are preferred but not required. Skipping 1 point makes a regular polygon with Points sides.
Pigment = The pigment to be applied to the star.
Background = The pigment to be applied to the background.
