POV-Ray : Documentation : 2.7.16 strings.inc
  POV-Ray 3.6 Documentation Online View
2.7.15 stdinc.inc   2.7.17 textures.inc
2.7.16 strings.inc
This include contains macros for manipulating and generating text strings.
CRGBStr(C, MinLen, Padding) and CRGBFTStr(C, MinLen, Padding)
These macros convert a color to a string. The format of the output string is "rgb < R, G, B>" or "rgbft < R, G, B, F, T>", depending on the macro being called.
Parameters:
  • C = The color to be turned into a string.
  • MinLen = The minimum length of the individual components, analogous to the second parameter of str().
  • Padding = The padding to use for the components, see the third parameter of the str() function for details.
Str(A). This macro creates a string containing a float with the systems default precision. It is a shortcut for using the str() function.
Parameters:
  • A = The float to be converted to a string.
VStr2D(V), VStr(V). These macros create strings containing vectors using POV syntax (<X,Y,Z>) with the default system precision. VStr2D() works with 2D vectors, VStr() with 3D vectors. They are shortcuts for using the vstr() function.
Parameters:
  • V = The vector to be converted to a string.
Vstr2D(V,L,P), Vstr(V,L,P). These macros create strings containing vectors using POV syntax (<X,Y,Z>) with user specified precision. Vstr2D() works with 2D vectors, Vstr() with 3D vectors. They are shortcuts for using the vstr() function. The function of L and P is the same as in vstr specified in String Functions.
Parameters:
  • L = Minimum length of the string and the type of left padding used if the string's representation is shorter than the minimum.
  • P = Number of digits after the decimal point."
Triangle_Str(A, B, C) and Smooth_Triangle_Str(A, NA, B, NB, C, NC)
These macros take vertex and normal information and return a string representing a triangle in POV-Ray syntax. They are mainly useful for generating mesh files.
Parameters:
  • A, B, C = Triangle vertex points.
  • NA, NB, NC = Triangle vertex normals (Smooth_Triangle_Str() only).
Parse_String(String). This macro takes a string, writes it to a file, and then includes that file. This has the effect of parsing that string: "Parse_String("MyColor")" will be seen by POV-Ray as "MyColor".
Parameters:
  • String = The string to be parsed.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
