| 2.7.11.1 Flat Distributions
  SRand(Stream). "Signed rand()", returns random numbers in the range [-1, 1].Parameters:
   Stream= Random number stream.
  RRand(Min, Max, Stream). Returns random numbers in the range [Min, Max].Parameters:
   Min= The lower end of the output range.
   Max= The upper end of the output range.
  VRand(Stream). Returns random vectors in a box from < 0, 0, 0> to < 1, 1, 1>Parameters:
  VRand_In_Box(PtA, PtB, Stream). Like VRand(), this macro returns a random vector in a box, but this
 version lets you specify the two corners of the box.Parameters:
   PtA= Lower-left-bottom corner of box.
   PtB= Upper-right-top corner of box.
  VRand_In_Sphere(Stream). Returns a random vector in a unit-radius sphere located at the origin.Parameters:
  VRand_On_Sphere(Stream). Returns a random vector on the surface of a unit-radius sphere located at the
 origin.Parameters:
  VRand_In_Obj(Object, Stream)This macro takes a solid object and returns a random point that is inside
 it. It does this by randomly sampling the bounding box of the object, and can be quite slow if the object occupies a
 small percentage of the volume of its bounding box (because it will take more attempts to find a point inside the
 object). This macro is best used on finite, solid objects (non-solid objects, such as meshes and bezier patches, do
 not have a defined "inside", and will not work).Parameters:
   Object= The object the macro chooses the points from.
   Stream= Random number stream. |
