Instead of placing the color of the image on the object like an image_map an image_pattern specifies an entire
texture item (color, pigment, normal or texture) based on the gray value at that point. This gray-value is checked
against a list and the corresponding item is then used for the texture at that particular point. For values between
listed items, an averaged texture is calculated. It takes a standard image specification and has one option, use_alpha
which works similar to use_color or use_index .
Syntax:
PIGMENT:
IMAGE_PATTERN
color_map { COLOR_MAP_BODY } |
colour_map { COLOR_MAP_BODY } |
pigment_map { PIGMENT_MAP_BODY }
NORMAL:
normal {
IMAGE_PATTERN [Bump_Size]
normal_map { NORMAL_MAP_BODY }
TEXTURE:
IMAGE_PATTERN
texture_map { TEXTURE_MAP_BODY }
IMAGE_PATTERN
image_pattern {
BITMAP_TYPE "bitmap.ext"
[IMAGE_MAP_MODS...]
IMAGE_MAP_MOD:
map_type Type | once | interpolate Type | use_alpha
ITEM_MAP_BODY:
ITEM_MAP_IDENTIFIER | ITEM_MAP_ENTRY...
ITEM_MAP_ENTRY:
[ GRAY_VALUE ITEM_MAP_ENTRY... ]
It is also useful for creating texture "masks", like the following:
image_pattern { tga "image.tga" use_alpha }
texture_map {
[0 Mytex ]
[1 pigment { transmit 1 } ]
Note: This pattern uses an image to get the gray values from. If you want exactly the
same possibilities but need to get gray values from a pigment, you can use the pigment_pattern.
