POV-Ray : Documentation : 2.5.11.17 Gradient
  POV-Ray 3.6 Documentation Online View
2.5.11.16 Function Image   2.5.11.18 Granite
2.5.11.17 Gradient
One of the simplest patterns is the gradient pattern. It is specified as
        gradient <Orientation>
        [PIGMENT_MODIFIERS...]
where <Orientation> is a vector pointing in the direction that the colors blend. For example
   pigment { gradient x } // bands of color vary as you move
                          // along the "x" direction.
produces a series of smooth bands of color that look like layers of colors next to each other. Points at x=0 are the first color in the color map. As the x location increases it smoothly turns to the last color at x=1. Then it starts over with the first again and gradually turns into the last color at x=2. In POV-Ray versions older than 3.5 the pattern reverses for negative values of x. As per POV-Ray 3.5 this is not the case anymore [1]. Using gradient y or gradient z makes the colors blend along the y- or z-axis. Any vector may be used but x, y and z are most common.
As a normal pattern, gradient generates a saw-tooth or ramped wave appearance. The syntax is
    normal {
        gradient <Orientation> [, Bump_Size]
        [NORMAL_MODIFIERS...]
where the vector <Orientation> is a required parameter but the float Bump_Size which follows is optional.
Note: the comma is required especially if Bump_Size is negative.
[1] If only the range -1 to 1 was used of the old gradient, for example in a sky_sphere, it can be replaced by the planar or marble pattern and revert the color_map. Also rotate the pattern for other orientations than y. A more general solution is to use function{abs(x)} as a pattern instead of gradient x and similar for gradient y and gradient z.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
