The dents pattern was originally designed only to be used as a normal pattern. It is especially
interesting when used with metallic textures. It gives impressions into the metal surface that look like dents have
been beaten into the surface with a hammer. Usually the dents are about 1 unit apart.
When used as a normal pattern, this pattern uses a specialized normal perturbation function. This means that the
pattern cannot be used with normal_map , slope_map or wave type modifiers in a normal
statement.
When used as a pigment pattern or texture pattern, the dents pattern is similar to normal dents but is
not identical as are most normals when compared to pigments.
