5.6.1 Special Command-Line Options
POV-Ray for Unix supports several special command-line options not recognized by other versions. They follow the
standards for programs that run under the X Window System.
-display <display_name>
Display preview on display_name rather than the default display. This is meant to be used to change the display
to a remote host. The normal dispay option
+d is still valid.
-geometry [WIDTHxHEIGHT][+XOFF+YOFF]
Render the image with WIDTH and HEIGHT as the dimensions, and locate the window
XOFF from the left
edge, and YOFF from the top edge of the screen (or if negative the right and bottom edges respectively).
For instance: -geometry 640x480+10+20 creates a display for a 640x480 image placed at (10,20) pixels
from the top-left corner of the screen. The WIDTH and HEIGHT , if given, override any
previous +Wn and +Hn settings.
-help
Display the X Window System-specific options. Use
-H by itself on the command-line to output the
general POV-Ray options.
-icon
Start the preview window as an icon.
-title <window_title>
Override the default preview window title with window_title.
-visual <visual_type>
Use the deepest visual of visual_type, if available, instead of the automatically selected visual. Valid visuals
are StaticGray, GrayScale, StaticColor, PseudoColor, TrueColor, or DirectColor.
Note: if you are supplying a filename with spaces in it, you will need to enclose the
filename itself within quotes.
