POV-Ray : Documentation : 1.3.4.4 Working With Pigment Maps
  POV-Ray 3.6 Documentation Online View
1.3.4.3 Finishes   1.3.4.5 Working With Normal Maps
Let's look at the pigment map. We must not confuse this with a color map, as color maps can only take individual colors as entries in the map, while pigment maps can use entire other pigment patterns. To get a feel for these, let's begin by setting up a basic plane with a simple pigment map. Now, in the following example, we are going to declare each of the pigments we are going to use before we actually use them. This is not strictly necessary (we could put an entire pigment description in each entry of the map) but it just makes the whole thing more readable.
  // simple Black on White checkerboard... it's a classic
  #declare Pigment1 = pigment {
    checker color Black color White
    scale .1
  // kind of a "psychedelic rings" effect
  #declare Pigment2 = pigment {
    wood
    color_map {
      [ 0.0 Red ]
      [ 0.3 Yellow ]
      [ 0.6 Green ]
      [ 1.0 Blue ]
  plane {
    -z, 0
      gradient x
      pigment_map {
        [ 0.0 Pigment1 ]
        [ 0.5 Pigment2 ]
        [ 1.0 Pigment1 ]
Okay, what we have done here is very simple, and probably quite recognizable if we have been working with color maps all along anyway. All we have done is substituted a pigment map where a color map would normally go, and as the entries in our map, we have referenced our declared pigments. When we render this example, we see a pattern which fades back and forth between the classic checkerboard, and those colorful rings. Because we fade from Pigment1 to Pigment2 and then back again, we see a clear blending of the two patterns at the transition points. We could just as easily get a sudden transition by amending the map to read.
  pigment_map {
    [ 0.0 Pigment1 ]
    [ 0.5 Pigment1 ]
    [ 0.5 Pigment2 ]
    [ 1.0 Pigment2 ]
Blending individual pigment patterns is just the beginning.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
