POV-Ray : Documentation : 5.3.7.1 Automated execution
  POV-Ray 3.6 Documentation Online View
5.3.7 POV-Ray for Unix Tips   5.3.7.2 Post-processing Images
POV-Ray for Unix is well suited for automated execution, for example, for rendering diagrams displaying statistical data on a regular basis or similar things.
POV-Ray can also write its image output directly to stdout. Therefore the image data can be piped in another program for further processing. To do this the special output filename '-' needs to be specified. For instance:
will pass the image data to the cjpeg utility which writes the image in the JPEG format.
The text output of POV-Ray is always written to stderr, it can be redirected to a file with (using a Bourne-compatible shell):
povray [Options] 2> log.txt
See also Directing Text Streams to Files.
For remote execution of POV-Ray, as for example in a rendering service on the web, make sure you read and comply with the POV-Ray Legal Document.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
