5.3.3.3 Output file formats
The default output file format of POV-Ray for Unix is PNG (+fn). This can be changed at runtime by setting the Output_File_Type
or +fx option. Eventually, the default format can be changed at compile time by setting DEFAULT_FILE_FORMAT
in the config.h file located in the unix/ directory.
Other convenient formats on Unix systems might be PPM (+fp) and TGA (+ft). For more information about output file
formats see File Output Options.
If you are generating histogram files (See CPU Utilization Histogram)
in the CSV format (comma separated values), then the units of time are in tens of microseconds (10 x 10-6
s), and each grid block can store times up to 12 hours.
