POV-Ray : Documentation : 4.5.2 Render Settings Dialog
  POV-Ray 3.6 Documentation Online View
4.5.1.5 Scenes Pane   4.5.2.1 Scene Pane
This modeless dialog box is displayed when the user selects the "Edit: Render Settings..." menu item. The user can set almost all of the POV-Ray command-line flags from this dialog. This information is saved in the currently open scene description file, so it is remembered between runs.
You can switch between the panes using the tab control near the top. You may switch back and forth between any or all of the panes and changing things. You can quickly cycle between the tabs by holding down the control and command keys and pressing the left arrow or right arrow key.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
