4.1.1 New Features in POV-Ray 3.5/3.6
The list is in no particular order.
Multiple open source files
Carbon compatibility
Easier to use Render Settings dialog
Extended preferences dialog
Improved text editor window with popup menus to jump to markers, declares, macros and includes and show dependent
files
Search Menu (Find, Replace, etc) with regular expression searching
Faster syntax coloring
Symbol coloring
Faster image preview window
Batch render multiple files with the extended Render Quene window
Preview and search templates in POV-Ray (requires CarbonLib 1.6 and later)
Render progress dialog
Improved message window to show statistics, errors and warnings
New preferences format that will never again be lost in a new version, it will not destroy 3.1 preferences, too!
New about box and startup screen
New application and file icons
Optional control of POV-Ray rendering via command-line arguments used on other platforms in Render Settings
dialog
Rendering runs in its own thread and no longer locks the user interface while rendering
Built-in just-in-time compiler for "function" generating native PowerPC code more than doubling speed
of isosurfaces in many cases
More control over POV-Ray via AppleScript
