POV-Ray : Documentation : 3.4.2.1 Preset Rendering Options
  POV-Ray 3.6 Documentation Online View
3.4.2 The Toolbar   3.4.2.2 Toolbar Command Line
This combobox contains a list of pre-set rendering options that you can choose just by clicking on one of them. By default, the list contains resolution and anti-aliasing related options, however, any POV-Ray option can be specified in the INI file that the list in the combobox is built from. It is easy to add your own entries to this list; see the section titled Adding New Resolutions for instructions.
Note that options entered on the POV-Ray command-line (via the toolbar, the command-line dialog, or the pvengine.exe command-line) will override any options specified by the above combobox.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
