3.2.6.8 The Tab Spacing Setting
The Tab spacing setting is a good example of a setting that applies to only the current file and to any new files
opened after that point. Like the language setting, it applies only to the current file. That is, changing the tab
spacing for one file does not automatically change it for all the other files that are already open. Like the language
setting, a files tab setting is stored with the MRU list, so if you re-open a file from the MRU list, the old setting
comes back.
Unlike the Language setting, however, the new value you apply to the tab value becomes the default for any file
opened or created after that point (apart from those in the MRU list). So if you change the tab setting to, say, 3,
the setting for the current file changes, but not that of any other open file. Any new file that you create or load
from that point, however, will be created with a default tab spacing of 3.
