3.2.6.6 Configuring the Internal Editor
The built-in editor is extensively customizable. It utilizes syntax highlighting and understands .POV and .INC
files as being in POV syntax. You can change the color settings used from the properties
dialog (Alt + Enter). It also has built-in syntax highlighting for C, C++, Java, Basic, Pascal, SQL, HTML and XML.
3.2.6.6.1 Important Editor Notes
One important thing to note right away is that the editor properties dialog
only allows you to set things that are implemented within the editor (remember, the editor is two components - a DLL
called 'CodeMax', and another DLL [written by the POV-Team] which loads and 'wraps' it into POV-Ray for Windows).
There are some other options implemented within the editor wrapper code in POV-Ray for Windows which are able to be
accessed via the Editor menu (only visible when an editor is selected). For example, the keybinding for saving a file
(Ctrl-S) is not listed in the editor properties since this function is handled by the wrapper code. You can't change
this assignment.
Additionally, by design, some properties only affect the current file, and some affect all files. Also, most (but
not all) of those that affect the current file will become the default for any new files opened after that point. This
is by design. For example, changing the tab stop setting only affects the current file (leaving other opened files
alone), but will then become the default for new files from that point on.
Some people have asked why the "don't ask again" option in the render save dialog is not persistent
across sessions. This is by design and is not likely to change.
The edit window context menu has an option for 'show/hide message window'. This window - when displayed at the
bottom of an editor window - is sizable. A quick way to close the message window is just to hit ESCAPE, or drag the
divider down to within a few pixels of the bottom border - when you release the mouse, the message window will vanish.
You can also tell POVWIN not to display the message window automatically when starting a render. You do this from
the Editor menu, by turning off 'Auto-Show Parse Messages'. This is most useful with the Error File option.
POVWIN will optionally automatically load a file in which a parse error has occurred into the editor (or select it
if it's already loaded) and place the cursor on the line and column of the offending code. This is able to be turned
on or off using the 'Auto-Load Error File' option in the Editor menu. Also, if this option is on, and the message
window was displayed automatically (see above), it will be closed automatically rather than being left open. The text
describing the error will be displayed in the status bar at the bottom of the window. Note that, occasionally, if the
error occurs inside a macro, the displayed line/column for the error will be wrong (though this is uncommon).
3.2.6.6.2 Default Key Mappings
Listed below is the complete set of default keystrokes and the CodeMax command that each keystroke maps to. Note
that many depend on caret position. If two sets of keystrokes are listed, either may be used (e.g. 'Copy' is defined
as 'Ctrl + C or Ctrl + Insert', which means that you may use either 'Ctrl + C' or 'Ctrl + Insert' to perform a copy;
whichever suits you. There is no difference between one or the other).
Note that if more than one key sequence is assigned to a command, and the command is one of those listed in the
menus (not all commands are listed in the menus), the key sequence shown as the shortcut key in the menu is generally
the shortest one (in terms of its printed representation).
You can change any of the below-mentioned key assignments if the defaults don't suit you. Additionally, the below
table does not list the more than 50 commands for which there is no default key assignment. Use Alt + Enter on
an editor screen, or select 'Codemax Properties' from the Editor menu to
assign these.
BookmarkNext
F2
Move to next bookmark
BookmarkPrev
Shift + F2
Move to previous bookmark
BookmarkToggle
Ctrl + F2
Place a bookmark
CharLeft
Left Arrow
Move caret left
CharLeftExtend
Shift + Left Arrow
Move caret left and highlight
CharRight
Right Arrow
Move caret right
CharRightExtend
Shift + Right Arrow
Move caret right and highlight
CodeList
Ctrl + Space
Show keywords (reference or insertion into file)
Copy
Copy selection to clipboard
Cut
Ctrl + X or Shift + Delete
Remove selection to clipboard
CutSelection
Ctrl + Alt + W
Remove selection (same as Cut)
Delete
Delete
Delete one character right (can Undo)
DeleteBack
Backspace or Shift + Backspace
Remove one character left (can Undo)
DocumentEnd
Ctrl + End
Move to end of file
DocumentEndExtend
Ctrl + Shift + End
Move to end of file and highlight
DocumentStart
Ctrl + Home
Move to start of file
DocumentStartExtend
Ctrl + Shift + Home
Move to start of file and highlight
Find
Alt + F3 or Ctrl + F
Find, or search
FindNext
F3
Find next (specified)
FindNextWord
Ctrl + F3
Find next (selected)
FindPrev
Shift + F3
Find previous (specified)
FindPrevWord
Ctrl + Shift + F3
Find previous (selected)
FindReplace
Ctrl + Alt + F3 or Ctrl + H
Find/Replace dialog
GoToLine
Ctrl + G
Move to a line number dialog
GoToMatchBrace
Ctrl + ]
Match brace }, bracket ], or parenthesis )
Home
Home
Move to start of line text (or line)
HomeExtend
Shift + Home
Move to start of line and highlight
IndentSelection
Tab
Indentation (number of spaces set in properties)
LineCut
Ctrl + Y
Remove current line
LineDown
Down Arrow
Move to next line
LineDownExtend
Shift + Down Arrow
Move to next line and highlight
LineEnd
End
Move to end of line text (or line)
LineEndExtend
Shift + End
Move to end of line and highlight
LineOpenAbove
Ctrl + Shift + N
Make new line above current line
LineUp
Up Arrow
Move to previous line
LineUpExtend
Shift + Up Arrow
Move to previous line and highlight
LowerCaseSelection
Ctrl + U
Change highlighted text to lower case
PageDown
Page Dn
Move down a page
PageDownExtend
Shift + Page Dn
Move down a page and highlight
PageUp
Page Up
Move up a page
PageUpExtend
Shift + Page Up
Move up a page and highlight
Paste
Ctrl + V or Shift + Insert
Place clipboard contents into file
Properties
Alt + Enter
CodeMax properties dialog
RecordMacro
Ctrl + Shift + R
Record/stop a macro
Redo
Ctrl + Y
Redoes last undone action (i.e. undo an undo)
SelectAll
Ctrl + A
Highlight entire file
SelectLine
Ctrl + Alt + F8
Highlight the current line
SelectSwapAnchor
Ctrl + Shift + X
Switch place of caret with start of highlighting
SentenceCut
Ctrl + Alt + K
Remove a continuous line to clipboard
SentenceLeft
Ctrl + Alt + Left Arrow
Move to start of continuous line
SentenceRight
Ctrl + Alt + Right Arrow
Move to end of continuous line
SetRepeatCount
Ctrl + R
Number of times to do next command
TabifySelection
Ctrl + Shift + T
Change highlighted spaces to tabs
ToggleOvertype
Insert
Toggle between inserting and overwriting
ToggleWhitespaceDisplay
Ctrl + Alt + T
Show or hide spaces
Undo
Ctrl + Z or Alt + Backspace
Undo last change
UnindentSelection
Shift + Tab
Remove indentation of selected line
UntabifySelection
Ctrl + Shift + Space
Change highlighted tabs to spaces
UpperCaseSelection
Ctrl + Shift + U
Change highlighted text to upper case
WindowScrollDown
Ctrl + Up Arrow
Scroll file down, leaving caret
WindowScrollLeft
Ctrl + Page Up
Scroll file left, leaving caret
WindowScrollRight
Ctrl + Page Dn
Scroll file right, leaving caret
WindowScrollUp
Ctrl + Down Arrow
Scroll file up, leaving caret
WordDeleteToEnd
Ctrl + Delete
Delete a word from caret to end
WordDeleteToStart
Ctrl + Backspace
Delete a word from caret to start
WordLeft
Ctrl + Left Arrow
Move to start of current word
WordLeftExtend
Ctrl + Shift + Left Arrow
Move to start of current word and highlight
WordRight
Ctrl + Right Arrow
Move to end of current word
WordRightExtend
Ctrl + Shift + Right Arrow
Move to end of current word and highlight
3.2.6.6.3 Setting Key Mappings
Most of the keystrokes used by the editor are re-assignable - even those listed in the menus. (Some users have
assumed that commands with shortcuts listed in the menus aren't assignable, but this isn't the case - if you change
the assignment, the new shortcut shows up in the menu).
Each editor command can have up to two different keyboard actions assigned to it, and each keyboard action may have
either one or two keystrokes. Most users will use only one keystroke, but those who are still familiar and comfortable
with the old 'Wordstar' key assignments (e.g. Ctrl-Q, F for Find) will be pleased to discover that these are still
available to them, should they want to take the time to assign them.
If you assign more than one key sequence to a command, and the command is one of those listed in the menus (not all
commands are listed in the menus), the one that is listed in the menu as the shortcut key is generally the shortest
You can access the keystroke assignments via the CodeMax properties dialog.
By default, this is mapped to Alt+Enter when an editor is displayed. Alternatively, you can get at it from the Editor
menu (only visible when an editor is selected) or the editor right-mouse-button context menu.
Not all commands are assignable ! In general, only the commands that are directly implemented in
the CodeMax editor DLL are able to be set. These commands are ones that relate to operations on individual edit
buffers. They do not include such things as file operations (load, save, print, etc). These operations are implemented
in the POVWIN editor wrapper code and are not managed or able to be changed by CodeMax. Therefore, it should be clear
that you can neither change the key bindings for operations such as file save, nor use the POVWIN- assigned keystroke
(e.g. Ctrl-S in the case of save) for any other purpose.
The editor supports the following mouse actions:
Left click over text
Changes the caret position
Right click over open file
Displays the pop-up menu
Left Button down over selection, hold and drag
Moves text
Ctrl + Left Button down over selection, hold and drag
Copies text
Left click over left margin
Selects line
Left click over left margin, hold and drag up or down
Selects multiple lines
Alt + Left Button down, hold and drag
Select columns of text
Left double click over text
Select word under cursor
Spin IntelliMouse (compatible) mouse wheel
Scroll the window vertically
Single click IntelliMouse mouse wheel
Select the word under the cursor
Double click IntelliMouse mouse wheel
Select the line under the cursor
Click and drag splitter bar
Split the window into multiple views or adjust the current splitter position
Double click splitter bar
Split the window in half into multiple views or unsplit the window if already split
3.2.6.6.6 European Users and Match Brace
Several European users have commented that the default key assignment for 'Match Brace' (Ctrl-]) is not usable on
their keyboards. Please note that you can change this to whatever you please (they assumed that it was not changeable
when, in fact, it is).
Another thing to remember about the match brace command is that it only works if it is executed when the edit caret
is on a brace character ('{', '}', '(', ')', '[', ']'). The caret will then jump to the matching character (e.g. if
it's on a '(', it will jump to the matching ')').
3.2.6.6.7 Global vs. Local Options
It's important to understand that many of the options that are accessible via the CodeMax properties dialog (Alt +
Enter by default), apply to the current file only. Some, however, apply to all files, and some apply to the current
file and all new files opened after that point. Confused yet ? ;). We'll explain more.
In most cases it should be obvious whether an option is global or not. As a quick summary, the options in the
'Misc' tab of the CodeMax properties dialog are all global. The ones in the 'Language/Tabs' section are as explained
above, except 'Convert tabs to spaces while typing', which is global, and 'Indent style', which is local and sets a
new default. Those in the 'Color/Font' section are global. Finally, key assignments are obviously global to all
editors (see the key assignment section above for caveats)
