POV-Ray : Documentation : 3.2.3 Dragging and Dropping Files
  POV-Ray 3.6 Documentation Online View
3.2.2 Starting a Render Job   3.2.4 Tutorials
Dragging and dropping from Windows Explorer (a.k.a. 'My Computer') has the advantage that you can select more than one file at a time. You can drag and drop up to 512 POV and/or INI files. POV-Ray for Windows will start processing the first file in the queue and add the rest to the queue. See File Queue in the Render Menu for more details.
Note: If the Drag'N'Drop Destination is set to Editor (the default), the files will be opened in the internal editor instead. In that case, there is a limit of 32 files (total) that may be opened.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
