2.8.8.3 Infinite Solid Objects
Describe a solid, possibly infinite, shape:
INFINITE_SOLID_OBJECT:
PLANE | POLY | CUBIC | QUARTIC | QUADRIC
The plane object:
PLANE:
Jump to SDL
plane { V_NORMAL, F_DISTANCE [OBJECT_MODIFIERS] }
The poly object:
POLY:
Jump to SDL
poly { ORDER, < POLY_COEFFICIENTS > [POLY_MODIFIERS] }
ORDER:
An integer value between 2 and 15 inclusive.
POLY_COEFFICIENTS:
A quantity n of FLOATs separated by commas, where n is
((ORDER+1)*(ORDER+2)*(ORDER+3))/6.
POLY_MODIFIERS:
[sturm [BOOL]] & [OBJECT_MODIFIERS]
The cubic object:
CUBIC:
cubic { < CUBIC_COEFFICIENTS > [POLY_MODIFIERS] }
CUBIC_COEFFICIENTS:
20 FLOATs separated by commas.
The quartic object:
QUARTIC:
quartic { < QUARTIC_COEFFICIENTS > [POLY_MODIFIERS] }
QUARTIC_COEFFICIENTS:
35 FLOATs separated by commas.
The quadric object:
QUADRIC:
Jump to SDL
quadric { < FLOAT, FLOAT, FLOAT >, < FLOAT, FLOAT,
FLOAT >, < FLOAT, FLOAT, FLOAT >, FLOAT [OBJECT_MODIFIERS] }
Quick Reference Contents
