POV-Ray : Documentation : 2.7.9.3 Vector Analysis
  POV-Ray 3.6 Documentation Online View
2.7.9.2 Vector functions and macros   2.7.10 metals.inc, golds.inc
SetGradientAccuracy(Value): all below macros make use of a constant named '__Gradient_Fn_Accuracy_' for numerical approximation of the derivatives. This constant can be changed with the macro, the default value is 0.001.
fn_Gradient(Fn): macro calculating the gradient of a function as a function.
Parameters:
  • Fn = function to calculate the gradient from.
Output: the length of the gradient as a function.
fn_Gradient_Directional(Fn, Dir): macro calculating the gradient of a function in one direction as a function.
Parameters:
  • Dir = direction to calculate the gradient.
Output: the gradient in that direction as a function.
fn_Divergence(Fnx, Fny, Fnz): macro calculating the divergence of a (vector) function as a function.
Parameters:
  • Fnx, Fny, Fnz= x, y and z components of a vector function.
Output: the divergence as a function.
vGradient(Fn, p0): macro calculating the gradient of a function as a vector expression.
Parameters:
  • p0 = point where to calculate the gradient.
Output: the gradient as a vector expression.
vCurl(Fnx, Fny, Fnz, p0): macro calculating the curl of a (vector) function as a vector expression
Parameters:
  • Fnx, Fny, Fnz = x, y and z components of a vector function.
Output: the curl as a vector expression
Divergence(Fnx, Fny, Fnz, p0): macro calculating the divergence of a (vector) function as a float expression
Parameters:
Output: the divergence as a float expression.
Gradient_Length(Fn, p0): macro calculating the length of the gradient of a function as a float expression.
Parameters:
Output: the length of the gradient as a float expression.
Gradient_Directional(Fn, p0, Dir): macro calculating the gradient of a function in one direction as a float expression.
Parameters:
Output: the gradient in that direction as a float expression
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
