Iridescence, or Newton's thin film interference, simulates the effect of light on surfaces with a
microscopic transparent film overlay. The effect is like an oil slick on a puddle of water or the rainbow hues of a
soap bubble. This effect is controlled by the irid statement specified inside a finish
statement.
This parameter modifies the surface color as a function of the angle between the light source and the surface.
Since the effect works in conjunction with the position and angle of the light sources to the surface it does not
behave in the same ways as a procedural pigment pattern.
The syntax is:
IRID:
irid { Irid_Amount [IRID_ITEMS...] }
IRID_ITEMS:
thickness Amount | turbulence Amount
The required Irid_Amount parameter is the contribution of the iridescence effect to the
overall surface color. As a rule of thumb keep to around 0.25 (25% contribution) or less, but experiment. If the
surface is coming out too white, try lowering the diffuse and possibly the ambient values
of the surface.
The thickness keyword represents the film's
thickness. This is an awkward parameter to set, since the thickness value has no relationship to the object's scale.
Changing it affects the scale or busy-ness of the effect. A very thin film will have a high frequency of
color changes while a thick film will have large areas of color. The default value is zero.
The thickness of the film can be varied with the
turbulence keyword. You can only specify the amount of turbulence with iridescence. The octaves, lambda, and
omega values are internally set and are not adjustable by the user at this time. This parameter varies only a single
value: the thickness. Therefore the value must be a single float value. It cannot be a vector as in other uses of the turbulence
keyword.
In addition, perturbing the object's surface normal through the use of bump patterns will affect iridescence.
For the curious, thin film interference occurs because, when the ray hits the surface of the film, part of the
light is reflected from that surface, while a portion is transmitted into the film. This subsurface ray
travels through the film and eventually reflects off the opaque substrate. The light emerges from the film slightly
out of phase with the ray that was reflected from the surface.
This phase shift creates interference, which varies with the wavelength of the component colors, resulting in some
wavelengths being reinforced, while others are cancelled out. When these components are recombined, the result is
iridescence. See also the global setting "Irid_Wavelength".
The concept used for this feature came from the book Fundamentals of Three-Dimensional Computer Graphics
by Alan Watt (Addison-Wesley).
