POV-Ray : Documentation : 2.4.2.2 Disc
  POV-Ray 3.6 Documentation Online View
2.4.2.1 Bicubic Patch   2.4.2.3 Mesh
2.4.2.2 Disc
Another flat, finite object available with POV-Ray is the disc. The disc is infinitely thin, it has no thickness. If you want a disc with true thickness you should use a very short cylinder. A disc shape may be defined by:
DISC:
    disc
        <Center>, <Normal>, Radius [, Hole_Radius]
        [OBJECT_MODIFIERS...]
Disc default values:
HOLE RADIUS : 0.0
The vector <Center> defines the x, y, z coordinates of the center of the disc. The <Normal> vector describes its orientation by describing its surface normal vector. This is followed by a float specifying the Radius. This may be optionally followed by another float specifying the radius of a hole to be cut from the center of the disc.
Note: The inside of a disc is the inside of the plane that contains the disc. Also note that it is not constrained by the radius of the disc.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
