POV-Ray : Documentation : 2.3.4.2 Adjusting Radiosity
  POV-Ray 3.6 Documentation Online View
2.3.4.1 How Radiosity Works   2.3.4.3 Tips on Radiosity
As described earlier, radiosity is turned on by using the radiosity{} block in global_setting. Radiosity has many parameters that are specified as follows:
    global_settings { radiosity { [RADIOSITY_ITEMS...] } }
RADIOSITY_ITEMS:
    adc_bailout Float | always_sample Bool | brightness Float |
    count Integer | error_bound Float | gray_threshold Float |
    load_file Filename | low_error_factor Float | max_sample Float |
    media Bool | minimum_reuse Float | nearest_count Integer |
    normal Bool | pretrace_end Float | pretrace_start Float |
    recursion_limit Integer | save_file Filename
Each item is optional and may appear in any order. If an item is specified more than once the last setting overrides previous values. Details on each item is given in the following sections.
Note: Considerable changes have been made to the way radiosity works in POV-Ray 3.5 compared to POV-Ray 3.1. Old scene will not render to the same result, if they render at all. It is not possible to use the #version directive to get backward compatibility for radiosity.
2.3.4.2.1 radiosity adc_bailout
You can specify an adc_bailout for radiosity rays. Use adc_bailout = 0.01 / brightest_ambient_object for good results. Default is 0.01.
2.3.4.2.2 always_sample
You can force POV-Ray to only use the data from the pretrace step and not gather any new samples during the final radiosity pass. This may reduce splotchiness. To do this, use always_sample off, by default it is on. It can also be usefully when reusing previously saved radiosity data.
2.3.4.2.3 brightness
The brightness keyword specifies a float value that is the degree to which objects are brightened before being returned upwards to the rest of the system. The default value is 1.0. In cases where you would raise the global_settings{ambient_light value} to increase the over all brightness in a non-radiosity scene, you can use brightness in a radiosity scene.
2.3.4.2.4 count
The integer number of rays that are sent out whenever a new radiosity value has to be calculated is given by count. A value of 35 is the default, the maximum is 1600. When this value is too low, the light level will tend to look a little bit blotchy, as if the surfaces you are looking at were slightly warped. If this is not important to your scene (as in the case that you have a bump map or if you have a strong texture) then by all means use a lower number.
2.3.4.2.5 error_bound
The error_bound float value is one of the two main speed/quality tuning values (the other is of course the number of rays shot). In an ideal world, this would be the only value needed. It is intended to mean the fraction of error tolerated. For example, if it were set to 1 the algorithm would not calculate a new value until the error on the last one was estimated at as high as 100%. Ignoring the error introduced by rotation for the moment, on flat surfaces this is equal to the fraction of the reuse distance, which in turn is the distance to the closest item hit. If you have an old sample on the floor 10 inches from a wall, an error bound of 0.5 will get you a new sample at a distance of about 5 inches from the wall.
The default value of 1.8 is good for a smooth general lighting effect. Using lower values is more accurate, but it will strongly increase the danger of artifacts and therefore require higher count. You can use values even lower than 0.1 but both render time and memory use can become extremely high then.
2.3.4.2.6 gray_threshold
Diffusely interreflected light is a function of the objects around the point in question. Since this is recursively defined to millions of levels of recursion, in any real life scene, every point is illuminated at least in part by every other part of the scene. Since we cannot afford to compute this, if we only do one bounce, the calculated ambient light is very strongly affected by the colors of the objects near it. This is known as color bleed and it really happens but not as much as this calculation method would have you believe. The gray_threshold float value grays it down a little, to make your scene more believable. A value of .6 means to calculate the ambient value as 60% of the equivalent gray value calculated, plus 40% of the actual value calculated. At 0%, this feature does nothing. At 100%, you always get white/gray ambient light, with no hue.
Note: this does not change the lightness/darkness, only the strength of hue/grayness (in HLS terms, it changes S only). The default value is 0.0
2.3.4.2.7 low_error_factor
If you calculate just enough samples, but no more, you will get an image which has slightly blotchy lighting. What you want is just a few extra interspersed, so that the blending will be nice and smooth. The solution to this is the mosaic preview, controlled by pretrace: it goes over the image one or more times beforehand, calculating radiosity values. To ensure that you get a few extra, the radiosity algorithm lowers the error bound during the pre-final passes, then sets it back just before the final pass. The low_error_factor is a float tuning value which sets the amount that the error bound is dropped during the preliminary image passes. If your low error factor is 0.8 and your error bound is set to 0.4 it will really use an error bound of 0.32 during the first passes and 0.4 on the final pass. The default value is 0.5.
2.3.4.2.8 max_sample
Sometimes there can be problems with splotchiness that is caused by objects that are very bright. This can be sometimes avoided by using the max_sample keyword. max_sample takes a float parameter which specifies the brightest that any gathered sample is allowed to be. Any samples brighter than this will have their brightness decreased (without affecting color). Specifying a non-positive value for max_sample will allow any brightness of samples (which is the default).
2.3.4.2.9 Media and Radiosity
Radiosity estimation can be affected by media. To enable this feature, add media on to the radiosity{} block. The default is off
2.3.4.2.10 minimum_reuse
The minimum effective radius ratio is set by minimum_reuse float value. This is the fraction of the screen width which sets the minimum radius of reuse for each sample point (actually, it is the fraction of the distance from the eye but the two are roughly equal). For example, if the value is 0.02, the radius of maximum reuse for every sample is set to whatever ground distance corresponds to 2% of the width of the screen. Imagine you sent a ray off to the horizon and it hits the ground at a distance of 100 miles from your eye point. The reuse distance for that sample will be set to 2 miles. At a resolution of 300*400 this will correspond to (very roughly) 8 pixels. The theory is that you do not want to calculate values for every pixel into every crevice everywhere in the scene, it will take too long. This sets a minimum bound for the reuse. If this value is too low, (which it should be in theory) rendering gets slow, and inside corners can get a little grainy. If it is set too high, you do not get the natural darkening of illumination near inside edges, since it reuses. At values higher than 2% you start getting more just plain errors, like reusing the illumination of the open table underneath the apple. Remember that this is a unit less ratio. The default value is 0.015.
2.3.4.2.11 nearest_count
The nearest_count integer value is the minimum number of old ambient values blended together to create a new interpolated value. The total number blended will vary depending on error_bound. All previous values that fit within the specified error_bound will be used in the average.
It will always be the n geometrically closest reusable points that get used. If you go lower than 4, things can get pretty patchy. This can be good for debugging, though. Must be no more than 20, since that is the size of the array allocated. The default value is 5.
2.3.4.2.12 Normal and Radiosity
Radiosity estimation can be affected by normals. To enable this feature, add normal on to the radiosity{} block. The default is off
2.3.4.2.13 Pretrace
To control the radiosity pre-trace gathering step, use the keywords pretrace_start and pretrace_end within the radiosity{} block. Each of these is followed by a decimal value between 0.0 and 1.0 which specifies the size of the blocks in the mosaic preview as a percentage of the image size. The defaults are 0.08 for pretrace_start and 0.04 for pretrace_end
2.3.4.2.14 recursion_limit
The recursion_limit is an integer value which determines how many recursion levels are used to calculate the diffuse inter-reflection. The default value is 3, the upper limit is 20.
2.3.4.2.15 Save and load radiosity data
You can save the radiosity data using save_file "file_name" and load the same data later using load_file "file_name". In general, it is not a good idea to save and load radiosity data if scene objects are moving. Even if data are loaded, more samples may be taken during rendering (which produces a better approximation). You can disable samples from being taken during the final rendering phase by specifying always_sample off.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
