POV-Ray : Documentation : 2.3.3.8 Max_Intersections
  POV-Ray 3.6 Documentation Online View
2.3.3.7 Max_Trace_Level   2.3.3.9 Number_Of_Waves
POV-Ray uses a set of internal stacks to collect ray/object intersection points. The usual maximum number of entries in these I-Stacks is 64. Complex scenes may cause these stacks to overflow. POV-Ray does not stop but it may incorrectly render your scene. When POV-Ray finishes rendering, a number of statistics are displayed. If you see I-Stack Overflows reported in the statistics you should increase the stack size. Add a global setting to your scene as follows:
 global_settings { max_intersections Integer }
If the I-Stack Overflows remain increase this value until they stop.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
