POV-Ray : Documentation : 1.2.2.2 Cone Object
  POV-Ray 3.6 Documentation Online View
1.2.2.1 Box Object   1.2.2.3 Cylinder Object
1.2.2.2 Cone Object
Here is another example showing how to use a cone:
  cone {
    <0, 1, 0>, 0.3    // Center and radius of one end
    <1, 2, 3>, 1.0    // Center and radius of other end
    texture { T_Stone25 scale 4 }
The cone shape is defined by the center and radius of each end. In this example one end is at location <0,1,0> and has a radius of 0.3 while the other end is centered at <1,2,3> with a radius of 1. If we want the cone to come to a sharp point we must use radius=0. The solid end caps are parallel to each other and perpendicular to the cone axis. If we want an open cone with no end caps we have to add the keyword open after the 2nd radius like this:
  cone {
    open              // Removes end caps
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
