POV-Ray : Documentation : 1.4.7.3 No beep when finished?
  POV-Ray 3.6 Documentation Online View
1.4.7.2 I'm getting a "Illegal grid value in dda_traversal()"   1.4.7.4 POV-Ray viruses?
"How can I get rid of the beep after POV-Ray has calculated the image"
Usually using the -P command-line option should help (POV-Ray will not pause after it has calculated the image). If you are using the windows version of POV-Ray, you can try Render -> On Completion -> Remove [v] in front of "Beep".
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
