POV-Ray for Unix version 3.7 | ||||
Home | POV-Ray for Unix | POV-Ray Tutorial | POV-Ray Reference |
This section points out the various types of text files that POV-Ray for Unix works with.
POV-Ray for Unix works with two types of plain text files.
The first is the standard POV-Ray scene description file. Although you may give files of this type any legitimate file name, it is easiest if you give them the .pov
extension. In this Help file, scene description files are referred to as POV files.
The second type, the initialization file. Initialization files normally have .ini
extensions and are referred to in this help file as INI files.
An INI file is a text file containing settings for what used to be called POV-Ray command-line options. It replaces and expands on the functions of the DEF files associated with previous versions of POV-Ray. You can store a default set of options in the main POV-Ray INI file which is searched for at the following locations:
POVINI
environment variable../povray.ini
$HOME/.povray/3.7/povray.ini
$PREFIX/etc/povray/3.7/povray.ini
($PREFIX
by default is /usr/local
)For backwards compatibility with version 3.5, POV-Ray 3.7 also attempts to read the main INI file from the old locations when none is found at the places above:
$HOME/.povrayrc
$PREFIX/etc/povray.ini
($PREFIX
)Note: Use of these locations is deprecated, they will not be available in future versions.
Any other INI file can be specified by passing the INI file name on the command line.
One of the options you can set in the INI file is the name of an input file. You can specify the name of a POV file here. This way you can customize POV-Ray settings for any individual scene file.
For instance, if you have a file called scene.pov, you can create a file scene.ini to contain settings specific for scene.pov. If you include the option Input_File_Name=scene.pov
in scene.ini, and then run povray scene.ini
, POV-Ray will process scene.pov with the options specified in scene.ini.
Remember, though, that any options set at the command line when you activate an INI file override any corresponding options in the INI file, see the section Understanding POV-Ray Options. Any options you do not set in the INI file will be taken as last set by any other INI file or as originally determined in povray.ini
You can instruct POV-Ray to generate an INI file containing all the options active at the time of rendering. This way, you can pass a POV file and its associated INI file on to another person and be confident that they will be able to generate the scene exactly the same way you did. See the section Using INI Files for more information.
Sections are not files in themselves; they are portions of INI files. Sections are a means of grouping multiple sets of POV-Ray options together in a single INI file, by introducing them with a section label. Consider the following INI file, taken from the POV-Ray 3 documentation:
; RES.INI ; This sample INI file is used to set resolution. +W120 +H100 ; This section has no label. ; Select it with "RES" [Low] +W80 +H60 ; This section has a label. ; Select it with "RES[Low]" [Med] +W320 +H200 ; This section has a label. ; Select it with "RES[Med]" [High] +W640 +H480 ; Labels are not case sensitive. ; "RES[high]" works [Really High] +W800 +H600 ; Labels may contain blanks
If you select this INI file, the default resolution setting will be 120 x 100. As soon as you select the [High]
section, however, the resolution becomes 640 x 480.
For more information on POV-Ray options and INI files consult the section on Setting POV-Ray Options.
